Old 07-13-2008, 03:52 PM
trib trib is offline
Question Amphenol connector install question
Hi,
I'm installing a female amphenol connector on a coax wire (RG-58U) for the transponder antenna. The connector is a 203/743-9272 from ASP. Does anyone have a PDF for instructions on how to install the connector or know of a link for instructions? Couldn't find one with a google search.
thanks
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 07-13-2008, 04:39 PM
Webb's Avatar
Webb Webb is offline
Default check out this post
This in one I started and got a ton of info.
http://www.vansairforce.com/communit...&highlight=bnc
Webb Willmott
Jackson, MS
N32WW
Old 07-13-2008, 06:51 PM
Jim P's Avatar
Jim P Jim P is offline
Tim,
I don't have the direct link, but go to Amphonal's website and do a search on the part number. There should be a .pdf for the install specs. It gives the specs for the stripping so you should be OK.
You can also go through Digikey, look up the part. There should be a link to install instructions from Digikey to Amphonal.
Here's a link to an example: http://www.amphenolrf.com/pdf/301.pdf
Jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
