07-13-2008, 10:49 AM
roll bar bolts
Wow, getting the nuts on those bolts through the roll bar, canopy deck and aft spacer is quite tricky with that canopy deck flange blocking access from the bottom.
Any tips??
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
07-13-2008, 11:01 AM
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
07-13-2008, 11:32 AM
Bent wrench
Any tips??
I heated and bent a cheap open end wrench. Couple of drops of superglue held the nut in the wrench while I worked it around the corner and up to the spot.
Don't use too much SG, or the wrench won't come off when you are done.
YMMV
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
07-13-2008, 12:45 PM
I used a box or closed in wrench with scotch tape in the wrench hole. Requires some patience but worked.
John
RV 9A
Finishing.
07-13-2008, 01:16 PM
thanks
Thanks guys, I went with the lower flange cutout option. Worked well.
Phil
RV9A (SB)
Ottawa, Canada
07-13-2008, 08:02 PM
Well, then, you don't need to know that hemostats are quite useful for getting into impossible places. They come straight and curved, various sizes, lock on to whatever it is you are trying to position, and are fairly inexpensive. I use them to put bolts in the tail hinges, rollbar, handle adel clamps (especially between the engine and firewall where the hands can't go), etc. The long ones also make handy backscratchers.
EAA Technical Counselor #5357
07-14-2008, 05:49 AM
Make your own wrench
By the time my 6 was done, I had made several specialty wrenches for various tight spots. It's not difficult. Just drill a hole in a piece of hardware store steel bar, file it to a hex shape with a small file, and if you need an open-end wrench, cut it in half. Then use your vise to bend the handle to whatever shape you need.
The wrench I made for the roll bar bolts was basically a "U" shape. I used some duct tape to hold the nut in the wrench until I got it threaded.
Jon Baker
RV6A sold, RV4 in-progress
Houston
