Old 07-12-2008, 09:39 AM
67MK Larry 67MK Larry is offline
Default alternator voltage problems
Hi new to the forum, have a 529Hour, 1994 RV6A, voltage is going from 13 to 16 every few seconds, any thoughts on what to look for first. Thanks Larry
Old 07-12-2008, 10:11 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Welcome aboard Larry!
Couple of thoughts/questions...
1) Is this a Van's internally Regulated alternator? If this is the case, then it is a Nippondenso you can read literally thousands of posts about them here), and you have probably gotten your service life out of it. Take it to the nearest auto parts store and get another - use it for another 529 hours for about a $100.
2) When mine went bad after a couple hundred hours, it exhibited the exact same thing - wandering voltage excursions. It went from "normal" to "uh-oh, I don't like this!" in just a couple hours, and I went and replaced it - I have an "all electric" airplane, and didn't want to take any chance on a real over voltage event.
3) Many will direct you to a Plane Power or B&C unit. These are GREAT systems as well! You will have to do some re-wiring, add an external regulator, etc. On the other hand, if I ever got 500+ hours out of a certified alternator on my old Grumman, I would have been ecstatic, so maybe the good old ND is good enough?
My thoughts,
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-12-2008, 10:58 AM
Default Alernator
Thanks for the advise Paul, not sure what alternator, I have will pull cowl today, just did first annual and mechanic had me busy in cockpit, I meant to recourd all equipment models and serial numbers firewall forward didnt get a chance. Thanks again....
Old 07-12-2008, 11:01 AM
gasman gasman is offline
WELL THEN LET ME BE THE FIRST........ well then, the third.......
Van's sells the PLANE POWER alternator kit. It is easy to install, has built in regulator and has built in over voltage protection. $375.00 This is the best price. This is not the same as an auto regulator. Go to their web site http://www.plane-power.com/Bit3.htm and read about this unit, then you will understand why yours failed at 500 hours.
The average car is driven about 500 hours a year. And alternators have no problem going for 10 (5000 hours) to 20 years. But place them in an aircraft and get only 10% of their life expected life???? It's like installing cheap tires..... except tires don't go bad DURING your flight and cause you to land before your battery goes dead.
I would expect Paul to upgrade next time around.........
Old 07-12-2008, 12:00 PM
Ironflight's Avatar
Well, I wouldn't rule it out, but I wouldn't hold my breath if I were you!
One of the nice things about the ND alternator is that if it goes out in Podunk Wherever, I can walk over to the auto parts store, pick one up, and be on my way. I've been stranded with dead (certified) alternators,and using the ND was a conscious decision to avoid that. Of course, I also have a backup alternator installed so that I don't have to terminate a VFR flight early!
Paul
Paul F. Dye
Old 07-12-2008, 12:12 PM
guccidude1 guccidude1 is offline
Default Re: alternator problems
My Van's alternator (60 amp) quit at 146 hours. Van's warranty is 6 months from purchase. I replaced it with an identical unit from Kragen's for $105, lifetime replacement warranty, now if I ever do need a replacement, Kragen is everywhere. Dan
Old 07-12-2008, 12:17 PM
Paul
I HAVE BEEN HOLDING MY BREATH for the past month!.........
We are downwind from the fire zone here in the NORTH part of California. 4 miles in haze.
As far as the Plane Power, I think if you read up about them, you will see that there is an auto parts alt that will fit right in place. BUT it will not have ov protection or any of the other features that Plane Power has. But it will get you going again. Less the core charge. ON the other hand you may NEVER need to do that again............
Old 07-12-2008, 12:19 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default Really?
Never heard of Kragen. Maybe I need to get out more
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 07-12-2008, 12:27 PM
Call a local alternator repair shop and ask them how Kragen alternators are rebuilt and or tested....
So who wants to remove their alternator every few hundred hours? Wait, you could just exchange it at every condition inspection.......
Old 07-12-2008, 01:53 PM
John Clark's Avatar
John Clark John Clark is offline
Default It's a regional thing
All the same company (CSK Automotive) but they do business as Kragen, Schuck's or Checker Auto Parts in various parts of the US.
John Clark
RV8 N18U "Sunshine"
KSBA
