Depending on which model of the PS-3000 you have, the shielded pair can either be a stereo input, or two unswitched mono inputs.
The PS Engineering website has the install manual for the intercoms, and this should clear things up.
If you have more than two auxiliary inputs required, you may need to build or buy an external mixer. I've done both in various panel designs. If you are interested in more info, go to my
vx-aviation website.
Thanks, Vern
