RG58 is fine.
For the lengths we use in our airplanes, RG58 works just fine. My transponder antenna is aft of the baggage area in my -6 and my transponder test shows max power out at every biannual check. Been working this way for over 15 years.
Also I agree that you should remove the short length of coax and make one continuous cable.
A male/female connection works fine, but it's just one more place for a failure.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
