Old 07-07-2008, 03:16 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Vent line- a different way
Some time back I remember seeing where some people had coiled the vent line tubing and kept it in the wing root area. The vent fixture was attached to the wing root fairing. It looks like a simpler alternative to the traditional run.
Anyone have information on this method?
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 07-07-2008, 03:19 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Originally Posted by RV7Guy View Post
Some time back I remember seeing where some people had coiled the vent line tubing and kept it in the wing root area....Anyone have information on this method?
http://www.vansairforce.com/communit...iled+vent+line
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 07-07-2008, 07:43 PM
Rockyjs Rockyjs is offline
Darwin,
I installed the fuel vents similar to the Rocket method. Due to the shorter skin overhang I riveted a piece of 063 for mounting the bulkhead vent fitting. I then drilled a clearance hole in the root fairing that goes over the vent. This allows the fairing to go on and off without having to disconnect the vent. If you do this I recommend temporarily attaching the fairing first to find where the holes lie and locatie the vent between attach points. I also drilled a # 60 hole in the top of the coil nearest to the fuel vent to act as an alternate air source in the event the vent became obstructed. I haven't flown yet, but have had the tanks full of fuel and run the engine. The vents work fine.
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
Old 07-07-2008, 11:56 PM
RV7Guy's Avatar
Default Just what I was looking for
Hi Rocky,
Thanks. This was exactly what I was looking for. Nice tip on have a secondary mounting flange. I'm going to do it this way.
Darwin N. Barrie
Chandler AZ
www.JDair.com
EMS Bell 407,
Old 07-08-2008, 05:37 AM
pierre smith's Avatar
Default It will drip...
.....much sooner this way. Van raises the top arc of the lines much higher his way. When you fill the tanks in the sun it will start dripping very shortly afterwards.
Van's way has the top of the vent line 18" higher than the coils.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 07-08-2008, 08:07 AM
DGlaeser DGlaeser is offline
Default Actually, no drips . . .
Regards,
I did mine this way and haven't had a drip yet - with temps into the 90's and full tanks.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 07-08-2008, 09:15 AM
captainron's Avatar
captainron captainron is offline
Default Long term?
Seems like a way to have some gummy old fuel remaining in the vent coils forever, though I could be wrong.........
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 07-08-2008, 09:33 AM
Default No long term problems...
Since the vent line is where the air comes from to replace the fuel being used, they will clear out every time you run on that tank.
Dennis Glaeser CFII
Rochester Hills, MI
Old 07-08-2008, 09:51 AM
rocketbob's Avatar
How about a check valve like the Lancair's use? Makes for a tidy installation, no coil of tubing to deal with. There's only a little dribbling when the tanks are full since the only fuel that can pass thru the check valve is thru the .040" bleed hole in the check valve's flapper door.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 07-08-2008, 11:19 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Default Status Update on Vent Coil
I posted some pictures of my install in the original thread. I thought folks would like an update after 200+ hours of using this installation.
It does run minor amounts of fuel out the vent when full and it's hot. Pierre is correct, at least for my installation anyway. Bob is also correct, I think some small check valves are in order here to cut the amount of drip down.
Overall, the amount of fuel is not that bad but can be noticable on a hot day, maybe a fuel tester cup's worth. However, I like the install better than running the lines up the side of the cockpit so I am willing to live with it.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
