Old 07-06-2008, 11:55 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Is 1/8" really sufficient for cowl-spinner gap?
I have my cowl all fitting pretty well. The top cowl may actually fit too well. Once drilled to the firewall, I ended up with a strong 1/8" (somewhere between 4/32" and 5/32") gap between spinner and cowl at the top and probably 1/4" at the bottom. Between a little bit of future sag, and a little bit of filler on the bottom half, I'm assuming this will eventually even out to something around 3/16" all around. However, if I end up with no sag, is 1/8" between cowl and spinner really enough over the long term? Van's says anything 1/8" to 1/4" is OK, but I'm just checking for confirmation from those with experience that being on the smaller side of that range will work out. Definitely don't want the spinner ever catching on the cowl on startup or any other time the engine might shake a little.
Side note: From the archives, I see that many nosewheel folks and those with 3-blade props prefer larger gaps (1/4" to 3/8") for ease in removing and installing cowl. However, I have no nosewheel and only a 2-blade prop, so I'm pretty happy with the smaller gap assuming it's conservative enough already.
Thanks for any tips.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jun. 2023
Old 07-07-2008, 01:30 AM
pauldan181 pauldan181 is offline
Hi Steve
I also wound up with a cowl-spinner gap similar to what you're seeing. After 60 hours now on my 8A there is no evidence that the spinner plate has ever touched the cowl. The engine has sagged a bit but the gap remains about 1/8" all around.
When you run the engine with the cowl off, watch the engine closely on start and shutdown. Most of the "shaking" is rotational with very little up/down or left right movement.
Hope this helps
Paul Danclovic
Old 07-07-2008, 05:51 AM
pierre smith's Avatar
Default Thrust...
Originally Posted by pauldan181 View Post
Hi Steve
Hope this helps
Paul Danclovic
.....will help increase the gap in flight as well, as the rubber mounts allow. With a C/S prop, the braking action at closed throttle might decrease the gap a bit, but not 1/8".
Regards,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 07-07-2008, 09:39 AM
Rick S. Rick S. is offline
I'm one of the nosewheel/three blade types and I needed about 3/8 of an inch. One thing about rotational movement is making sure the metal portion of the baffle has adequate clearance from the underside. IF it's too close the metal may contact the cowl with bad results.
Rick Sked
Old 07-07-2008, 09:59 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
1/8 with nose gear and a 3 blade prop WILL make for a miserable cowl removal experience. 2 blade and TW you are ok.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 460.7 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 07-07-2008, 10:16 AM
David_Nelson's Avatar
David_Nelson David_Nelson is offline
Default 3/8" it is...
Ross,
Thanks for the heads up on the spacing with a 3-blade prop!
/\/elson
RV-7A Tip-Up
NW Austin, TX
Old 07-07-2008, 10:20 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
I've got a Catto three blade and 1/8" spacing and do not have any issues with install or removal of the cowling. I think it really depends on how you final trim and fit the cowling.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 07-07-2008, 10:59 AM
N941WR's Avatar
N941WR N941WR is offline
Steve,
I have about a 3/8 to 1/4" gap and it works fine. I also trimmed the lower cowling, per one of the RVator's to help with the removal of the lower cowling.
Which engine mount do you have? The conical mount on my engine sagged much more than I ever thought it would, about 3/8" or so.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-07-2008, 11:12 AM
rvbuilder2002's Avatar
Originally Posted by David_Nelson View Post
Ross,
A three blade prop doesn't require more gap from the spinner...it requires a deeper slot (cut further forward) for the nose gear so that the cowl can be lowered down much further to clear the prop blades. I had probably the first RV "A" model with a 3 blade prop back in 1993. I just made an aluminum cover to screw over the slot in the cowl bottom.
BTW a 1/8" gap works fine (in fact an even 1/16" works with no rubbing on most installations) but the closer the gap, the higher the difficulty of removing and installing the cowl. Especially if there is an improper interface between the FAB and the induction air inlet.
Scott McDaniels
Hubbard, Oregon
Van's Aircraft Engineering Prototype Shop
FAA/DAR
Old 07-07-2008, 11:21 AM
Yep... what Scott said!
Reiley
VAF# 671
Friend of the RV-1
