Old 07-06-2008, 06:47 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Inverted Pickup Fuel Line-Am I missing something?
Gents,
Those of you out there with RV-6/7/8 with an inverted pickup in your tank(s) you maybe able to help.
I am finishing the fuel line plumbing to the fuel tanks on my RV-7A (wings are on temperorily). I am building the fuel line per the plans. I began feeding and bending the fuel line to the inverted pickup tube bulkhead fitting on the tank. After just about completing the routing I was ready to flare the fuel tank end of the line when it occurred to me that I might have some trouble actually putting the tank on with this continuous fuel line. So I tried to install the tank and found that I indeed could not get in on due to the line interfering with the fuel tank forward attach bracket.
Am I missing something? A simple fix would be to cut the fuel line and install a AN coupling in the wing root area.
Please enlighten me. What have other done?
Paul
Old 07-06-2008, 06:58 PM
rrd1_99 rrd1_99 is offline
Default Use a bulkhead fitting
I am going to install a bulkhead fitting at the fuselage and Aeroquip hose from there to the tank. I know plenty of others have done this for ease of installation.
Of course, I already cut a 1" hole in both sides of the fuse for the aluminum tubing, but I think I will just pop rivet a cover plate over those holes and install the bulkhead fitting in that plate.
Roger
Old 07-07-2008, 04:51 AM
kiwipete kiwipete is offline
Paul
My tank was already attached to the wing so fitting it was straight forward.
I routed the line in one length and used a rubber grommet where it passes through the forward tank attachment.
Peter
Old 07-08-2008, 06:20 AM
aerolite aerolite is offline
Default Inverted fuel line
Paul,
I ran the fuel line just out of the fuse then did a seperate line with a 90 degree elbow at fuse and straight into flop tube.
Steve
RV7 FF
Old 07-10-2008, 09:06 AM
Pirkka Pirkka is offline
Originally Posted by aerolite View Post
Steve
RV7 FF
This is the picture I've wanted to see for a long time. I haven't found decent pictures from the drawings but this really tells what is between wing and fuselage. Thank you! Anyone have similar picture from another side of the center spar?
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
