Old 09-08-2005, 07:54 PM
dwilson dwilson is offline
Default RTV question
I am ready to rivet the trailing edges of my elevators and glue in the foam ribs on the trim tab.
Another thread mentioned RTV instead of ProSeal. Said to "be sure and get acid free"
Went to the automotive store today and looked for "acid free" RTV. The guy looked at me like I was from New Orleans. He sold me a tube of RTV.
I plan to use this on the trailing edges tonight. Can I use it on the foam ribs too, or will it melt them?????
Duane
Old 09-08-2005, 08:09 PM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
If it says "oxygen sensor safe", then you're ok.
William
Old 09-08-2005, 08:29 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Wouldn't use it
I wouldn't use RTV. Unless you plan to leave the plane bare aluminum you'll play **** painting the rudder. Where ever the RTV is the paint is not going to stick.
If you don't want to use Proseal, consider epoxy and micro balloons. Slow cure epoxy will give you plenty of working time. When it cures you can block sand the TE to clean it up. Not nearly as messy as proseal with the same results.
Darwin N. Barrie
Chandler AZ
Old 09-09-2005, 06:13 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Use a piece of smooth steel angle, drill the holes to match the rivet pattern, and hold the pieces that way. just drill every other hole. You won't need glue then. Hold the parts with clecoes and place a rivet in the other holes and shoot them down partially. Remove the piece from the angle and finish on your back rivet plate.
Worked for me,
Roberta
Old 09-09-2005, 06:51 AM
penguin penguin is offline
Default Pep Boys?
I got some from Pep Boys - Ultra black permatex, it said low acid or no acid (can't remember) on the cardboard carrier.
Pete
Old 09-09-2005, 07:04 AM
flybill7 flybill7 is offline
A repeat offender advised me to use Marine West Epoxy mixed with cotton flox and it worked fine.
Bill Cloughley
Severna Park, Maryland
RV-7 Flying (1,400 hours)
http://www.pilotbill.com
Old 09-09-2005, 10:36 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Duane,
There's a lot going on in your message. Maybe I can help.
Why use foam? I would install small aluminum ribs. It's probably more work to make, but less work to finish and it will last forever. Whatever you stuff over the foam (slurry or flox) will eventually crack and the paint will chip. Aluminum and fiberglass have different coefficients of expansion and cracks are inevitable.
Three things here. First, I would never put RTV where you want to paint. Paint just won't stick to it and even if it does, it won't stay there for long. Two, RTV will not hold as well as ProSeal and is generally, not that good of an adhesive in this situation. The RTV will allow the part ot move just slightly, thus assisting in the aforementioned cracking. Third, acid-eating RTV is an urban legend. When the RTV sets, it is basically inert and no threat to "eat a hole in your aluminum" as the legend goes.
Went to the automotive store today and looked for "acid free" RTV. The guy looked at me like I was from New Orleans. He sold me a tube of RTV. I plan to use this on the trailing edges tonight. Can I use it on the foam ribs too, or will it melt them?????
Yes, RTV will dissolve certain foams. It all depends on what you are using. All round, I don't think you'll be happy with foam ribs but it's your rig, do what you'd like. A previous poster mentioned using flox as a cover. You can do that but that stuff is a real bear to sand and that's not really the intent of flox. What you really want is a dry mix of slurry (microballons). I would cover it with one layer of glass cloth first before applying any surfacer as this aids adhesion.
(Graduate of the Rutan School of Fiberglassing)
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 09-09-2005, 10:56 AM
arffguy arffguy is offline
These are the interior parts, right? What is the worry about painting over it????????
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid anyway
Old 09-09-2005, 11:16 AM
The foam ribs are inside the trim tab just to stiffen it a little bit. They are what Vans calls for in their plans.
I appreciate all your input. I will use ProSeal and finish these parts up this weekend!
Duane
Old 09-09-2005, 01:45 PM
f1rocket's Avatar
My bad, I thought they were the end ribs.
Randy Pflanzer
Greenwood, IN
Paid through 2043!
