Old 07-03-2008, 10:01 AM
TerryWighs TerryWighs is offline
Default Fuel tank dimple dies???
I am working on fuel tanks. I have seen reference to "fuel tank dimple dies"??? So far, I have been unsuccessful in finding this specialty tool part or if using this dimple die is really necessary?
Can anyone clear this up for me?
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
Old 07-03-2008, 10:19 AM
N526JS's Avatar
N526JS N526JS is offline
Ckeveland has them. You will want to use them as they make a slightly deeper dimple so that the rivets will sit flush with the sealant (ProSeal) under them.
http://www.cleavelandtoolstore.com/p...umber=DIE4263T
Old 07-03-2008, 10:32 AM
Thanks Jim...
Fairbanks, Alaska
empennage done
Wings done
Old 07-03-2008, 11:03 AM
vmirv8bldr's Avatar
vmirv8bldr vmirv8bldr is offline
Default Avery too
Got mine from Avery.....
One note: The slightly deeper dimple combine with the slight lubricating effect of proseal means you can silde off these much easier with the flush set and can get it going at a slight angle. Just be extra cautious about keeping the rivet gun perpendicular when you pull the trigger.
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
