Old 07-02-2008, 03:07 PM
jimgreen jimgreen is offline
Default canopy hinge blocks
I'm just preparing to drill the hinge blocks to the short ribs(f 644). When I cleco on the top skin with the blocks in place it is tight and hard to line up the short ribs to insert the clecos.
It looks like it's going to be very tough to push the goose necks between the hinge blocks as the space is only about 3/16ths.
Do I press on and sand down the blocks later or what?
Just found out the 617 blocks are over size - 13/16ths. Next question is, has anyone had success sanding down UHMW ? The blocks are too small to plane.
Old 07-02-2008, 03:26 PM
fstringham7a fstringham7a is offline
Default RE; Canopy isn't it fun!!!!!
Jim
I believe (its been a while....since this activity..) I put the canopy on before I clecoed the skin on. This way it was easy to get it in and put the skin on after it is on. Check out Dan C web page for some great advice.
http://www.rvproject.com/20030220.html
Also be very careful when lifting the canopy as the forward skib of the canopy wants to catch the aft edge of the deck skin........
Frank @ 1L8 ....RV7A....last 925 details...paint is next
Old 07-02-2008, 06:20 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Suggestion
A builder named Jeff Bordelon had a really good order he did his in, that worked well for me. He did it different than planned and it made good sense and worked well. Lots of nice big pics. Good luck
http://jeffsrv-7a.com/FUSELAGE/05-01-12.htm
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Last edited by RickWoodall : 07-02-2008 at 06:35 PM. Reason: looked up link and added.
Old 07-10-2008, 03:22 PM
Default follow up to hinge block trimming
Just as a follow up for anyone checking out this thread.
I found my belt sander wouldn't touch the UHMW plastic, but had success trimming the blocks to 3/4" thickness on my table saw. Just watch your fingers.
