07-02-2008, 10:51 AM
O-320-D2A
What is the difference between an O-320-D1A and an O-320-D2A?
Vans sells the D1A, but I'm looking at an overhauled D2A, will it still be compatible with my cowl etc?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
07-02-2008, 11:02 AM
TC Data Sheets
Do a search for 'type certificate data sheet' (TCDS) for the O-320. It's the FAA doc that will list operating limitations and differences by model.
Link McGarity
Wellington, FL (FD38)
RV6/N42GF bought flying, sold
RV6/N72AT bought flying, sold
B737-800/NxxxAN
Sonex TD w/Aerovee/N732SX bought flying
07-02-2008, 11:09 AM
SECTION 11 CONST. MANUAL (RV6)
EXPLAINED IN THE engine and prop section..........
D2A is the same as D1A but with fixed pitch propeller and 3/8" attaching bolts.
07-02-2008, 11:36 AM
D2A can usually be turned into a D1A (constant speed version) for about $300 in parts if you bought your D2A from Aerosport, or about $500 in parts if you did not.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
07-02-2008, 12:13 PM
Hollow Crank D1A, Solid Crank D2A
The information I have on this is a little different. D2A has solid crankshaft, D1A has hollow crank. To convert D2A to D1A, you need to at least swap out the crankshaft, which is at least an order of magnitude greater in cost than your parts quote above.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
