Old 07-01-2008, 09:58 PM
luke42179 luke42179 is offline
Default Intermittant Transponder problem
Hey gents,
My King transponder shows a blinking, sometimes steady light, but ATC says they can't see me, like it isn't on. Any ideas?
thanks
Luke
Oceanside, CA
Old 07-01-2008, 10:03 PM
Bryan Wood's Avatar
Bryan Wood Bryan Wood is offline
Default Look here
Here are some past transponder posts. Maybe something here can help you out.
Bryan 9A Sold
Beech S35, and daydreams of a Super 8 or a Rocket starting to take over my brain.
Old 07-01-2008, 11:04 PM
LOGGY LOGGY is offline
Default transponder
I had the same problem....Check the antenna conection...That was my trouble
Old 07-01-2008, 11:05 PM
petehowell's Avatar
Default My Thoughts
I was the king of transponder issues for a while. I found two things.
1) I had a bad connector in my transponder antenna lead - it allowed my transponder to receive signals (blink) but it would not send the signal out. I replaced the connector and it was all good again.
2) I got a tip that the ignition system would cause issues (constant replying) with the transponder due to noise it kicks off. I use EI and auto plugs and my transponder goes a bit nuts if the nubs on the top of the plugs are not screwed on tight, or if the leads are not snapped on tightly.
Good luck.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 07-02-2008, 12:08 AM
TwoDogsOneAirplane TwoDogsOneAirplane is offline
Default Could be your altitude encoder...
My problem turned out to be the altitude encoder. The reason they could not "see" me was the altitude reported was way off and the controller's console didn't show the airplane.
Old 07-02-2008, 12:00 PM
Thumbs up thanks
Thanks All
It sounds like I need to check that antenna connector before sending the transponder in for repair.
