Old 06-28-2008, 10:59 PM
danielhv's Avatar
danielhv danielhv is offline
Default What size dowel for folding trailing edges?
Working on folding the elevator trailing edges... I've heard some ppl using 1/8" dowels, and some using 1/4" dowels... which do I need to buy?
Old 06-29-2008, 07:05 AM
RV8N RV8N is offline
I tried to use the dowel but it didn't seem to help.
My favorite way to bend the trailing edges is with a seamer made out of vise grips. I adjust the seamer fairly wide and gradually clamp it to the trailing edge, working my way down the length. Gradually adjust the seamer a little tighter and repeat until the end ribs slide in and are making contact with the skin.
Karl
Now in Sandpoint, ID.
RV-8 #80240 SOLD
1999 BMW R1100RS
Old 06-29-2008, 07:13 AM
FredMagare FredMagare is offline
A 1/4" dowel will give you a 1/8" radius on the traling edge. (go smaller and you may crease/crack the trailing edge.) Tape it in position so it doesn't move away and apply gentle/even pressure with something like a straight 2x4 or piece of aluminum angle. (originally learned through construction of an RV-6 emp.)
Good luck!
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 06-29-2008, 05:43 PM
Hawkeye7A's Avatar
Hawkeye7A Hawkeye7A is offline
Default Here's what I did
I got a nice straight piece of 2 x 8 lumber, trimmed it to the length needed for the control surfaces (can't remember how long, been awhile) and had a friend with a good table saw rip it down the middle. I fastened the two halves together with three heavy hinges. I then drilled a few crossholes through the lower half to bolt it to the edge of my bench with the split flush with the benchtop. A couple of vertical holes partway into the top of the upper piece to allow me to stick a couple of steel rods in to give me levers to apply the breaking action. Didn't use dowels and just added a bit more bend until the ribs slipped in and just touched the skin. Took longer to write this than it did to fabricate the tool. Hope this helps.
--Hawk Pierce
RV-7A Flying as of Sep 7, 2008
Phase One complete as of Nov 16, 2008
Finally painted!
600+ hours and lovin' every minute of it!
N728E
SE AZ
"I fly because it frees my mind from the tyranny of petty things."
--Antoine de Saint Exupery
Old 07-01-2008, 05:12 PM
osxuser's Avatar
osxuser osxuser is offline
Yep, I did the same, per the plans. Pics at RVproject.com too...
RV4 wing in Jig @ KPOC
RV7 emp built
Old 07-01-2008, 10:29 PM
chunt0 chunt0 is offline
Default Trailing Edge Radii
My 7 drawing 4PP says the elevator trailing edge radius should be 3/32, and that certainly appears to be an outside dimension. Because of metal thickness and springback, a 3/16 diameter dowel magically held in position (dowels will want to squirt out) won't let you get a radius as tight as the drawing calls for. a 1/8 (4/32) diameter dowel should allow you to get there, but over squeezing is bad news. Too tight a radius results in a weak structure, increases the risk of cracking, and makes it more likely you will end up with a crooked trailing edge.
My drawing 5PP shows a radius of 3/32 for both the elevator and rudder (early, bent trailing edge rudders).
My drawing 7PP shows a radius of 1/8 for the same early rudder--Van's can't be accused of making things restrictively consistent for us. I take this to mean they are comfortable with anything between the two numbers, but a call to them would never hurt.
My aileron instructions say to use a radius of 3/32 to 1/8. My aileron drawing seems to show a 1/8 radius.
I made a simple go-no go gauge from a flat piece of aluminum. It has two notches. One notch has a 3/32 apex radius, and the other has a 1/8 radius.
Make sure you have a very flat surface leading up to the trailing edge. Another hint is to make sure your bending brake surface is as flat as possible.
Charlie
RV-7A
Canton, MI
