06-28-2008, 08:31 AM
f-6119, is it needed
Hello,
Yesterday I got to the point in the build where I needed to join the rudder cables to the rudder pedal assembly. On the drawings, dwg 37, it shows that a part is made, F-6119 a rudder cable link, but my cables reach the rudder assembly and don't need that part.
I bolted the cables right to the rudder pedal assembly using the proper called out bolt, washers, castle nut and pin.
Is there a problem bolting the cable directly to the rudder pedal assembly? Will this make the connection weaker?
Mike Ice
RV-9, should take this assembly of parts to the airport this next week.
06-28-2008, 08:42 AM
Maybe...
.....they'll be too short to reach the rudder horn. Have you checked? We needed them on our -6 and most all -7's I've seen use them.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Wow, you must be short, with those pedals installed way back. I don't see any problem as long as everything lines up and doesn't bind at the extremes of travel. I'm assuming you have tested the fit with full seat cushions installed.
Scott Card
CMW E-Lift
06-28-2008, 09:08 AM
Unless you have a forked end fitting on the cable you'll be putting the joint in single shear instead of having it evenly balanced as with the pair of F-6119 links. You might then bend and break the lug on the rudder pedal and tilt the bolt over at an angle, especially if it is loose enough to pivot as it should be. Everything will feel less firm and be half as strong.
Jim Sharkey
RV6 - Finishing Up
Reason: tilt was **** but it was ****ed out
06-28-2008, 09:19 AM
Jim Sharkey
RV6 - Finishing Up
What Jim said.
You need to at least make some very short links.
Scott McDaniels
Hubbard, Oregon
06-28-2008, 09:28 AM
Ah, yes indeed. I had forgotten that that end wasn't a fork.
Scott Card
CMW E-Lift
06-28-2008, 09:42 AM
Too far away.
Looks like you are in Alaska. If you were closer, I would volunteer to help you shorten you cables. I have an MS Swager.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
06-28-2008, 11:18 AM
yes, I am short, but
Thanks for the replies.
Mel, I thought about the swager but didn't want to get too radical and cut the cable right away.
Scott, I am 5' 8" I just like the rudder pedals to be close, it suits my stlye of flying.
Pierre, I already have the cables attached to the rudder horn but thanks for the thought.
Jim, I thought there might be some problems with a side load on those bolts and your comments support that idea.
So... I guess I will look at moving the rudder pedal assembly back just a little and make up some short (vs hot) links.
Fitting the rudder fiberglass tip this morning. Hope to get this plane fledged out of the garage and off to the airport this next week.
Mike
06-28-2008, 11:32 AM
Could you weld another tab onto the tube stucture thereby making it a fork?
06-28-2008, 11:41 AM
welding
Rivethead,
While the welding idea is certainly viable it isn't the best right now. To weld on this assembly, I think, I would have to take the assmbly out of the aircraft. My welding skills are good, but not that good, to allow me to weld in the aircraft up under the instrument panel.
Mike
