Old 06-27-2008, 01:08 AM
scsmith scsmith is offline
Default question on low oil temps
Periodically there are posts that have to do with partially blocking off the oil cooler during seasons when the oil temp runs too cold.
I have a question about this: Doesn't the Vernatherm valve restrict the oil flow to the cooler at low temperatures to help maintain a set oil temperature?
Steve
RV-8QB FWF
Old 06-27-2008, 05:50 AM
Geico266's Avatar
Geico266 Geico266 is offline
It is suppose to work that way, but they just don't seem to do the job. IMHO you need a way to block the airflow off inflight or add an oil thermostat.
I have been toying with the idea to use this oil thermostat to a Lycoming. I have used these for years on Rotax 912 (S). They work flawlessly to maintain oil temps at 180F.
http://www.perma-cool.com/Catalog/Cat_page14.html
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
