Old 06-26-2008, 04:03 AM
tinman tinman is offline
Default Baffles- Tension Rod Thread Cutting
The tension rods on the bottom of the baffles are stainless steel. I have had no luck with cutting threads on them...my die won't even scratch it. Any hints?
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
Old 06-26-2008, 04:59 AM
Rick6a's Avatar
Rick6a Rick6a is offline
I had the same trouble until I purchased a higher quality die.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 06-26-2008, 06:14 AM
Scott Hersha Scott Hersha is offline
Default Thread cutting
I guess the dies I inherited from my late father-in-law were good ones (they're probably as old as me - and I ain't young). I didn'nt have any trouble either.
Scott Hersha
Old 06-26-2008, 06:19 AM
Webb's Avatar
Webb Webb is offline
Default Use something bigger
I used a small bolt cutter like you would cut a lock. Then used a bench grinder and cleaned up the cut and rounded the corner. Nut went right on.
Webb Willmott
Jackson, MS
N32WW
Old 06-26-2008, 08:55 AM
Rick_A's Avatar
Rick_A Rick_A is offline
I had real trouble getting the first thread cut - in other words, I had a problem getting it started.
I finally figured out that if I put a good taper on the end (using my medium polishing wheel) the die would seat on the rod end and it was much easier to get it going. Then it was just a matter of working it back and forth making a little progress each time.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 06-26-2008, 09:00 AM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Default Threaded rod
I bought stainless threaded rod, and bent it gently to go around the higher (lower) spots on the cylinders.
As Webb mentioned in a previous post, then cut and clean the ends. I suspect Webb used a threaded rod as well.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 06-26-2008, 10:30 AM
Webb's Avatar
Default Let me clarify
I should have said die instead of nut (duh). The rods were solid, not threaded.
You HAVE to taper the end slightly to get the die to bite. Clamp the rod in your vise and use plenty of oil. I had the same problem. Start the die and progress slowly, work back and forth and it will happen. The key is to taper the end so the die will bite. (trust me)
Webb Willmott
Jackson, MS
N32WW
Old 06-26-2008, 12:33 PM
Thanks everyone.
I will go buy a good die and throw out my cheapie from The Land of Not Quite
Right.
Don Alexander
Summerville, SC
Old 06-26-2008, 12:50 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
What's wrong with the good ole tie wire method? You will not be cussing the nuts on stainless down the road...
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 06-26-2008, 03:13 PM
Webb's Avatar
Default Don't throw yet
Thanks everyone.
Right.
Before you throw, taper it and see if it will bite. Once it starts to bite, it will cut it. Don't forget the oil and work it back and forth eating a little up with each new turn.
Webb Willmott
Jackson, MS
N32WW
