Old 06-24-2008, 05:29 PM
szicree szicree is offline
Question Favorite Paint Remover for PPG DP Primer?
I need to remove some cured DP Epoxy from aluminum. I tried some aircraft stripper once and it worked just ok. I actually found acetone and a rag to work just as well. Anybody got a good recommendation on what will work real well??
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 06-24-2008, 06:04 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation PTI
Steve... I've used the PTI PRY stripper from Aircraft Spruce on 30 year old DuPont Colar epoxy primer.
It worked quite well, but don't get any on your skin, it will burn...
http://www.aircraftspruce.com/catalo...tiremovers.php
...but if acetone and a rag worked on your DP epoxy, it wasn't really cured (or mixed well)... epoxy primers should be quite resistant to acetone.
...and it's just down the street from you...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-24-2008, 08:19 PM
Thanks Gil. I'll give it a try. Re the acetone thing, I was surprised as well. It takes a little rubbing, but it does cut right through the DP. The stuff was mixed per specs and has cured for many months (years even). It's the lead-free DP, but I wouldn't think that would matter.
Steve Zicree
Old 06-24-2008, 09:49 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
Try a stripper called oddly enough "Aircraft Remover." No it doesn't erase your airplane from planet Earth, but it does do a heck of a job removing paint, very easy. And even more strange is that it is usually available at common auto parts stores.
Jerry
