Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
  #11
Old 06-24-2008, 10:41 AM
Doug Rodrigues Doug Rodrigues is offline
Default A little modification needed....
You'll have to relocate your wing forward about 5 feet and cut the prop tips back a bit. Add 50 gallon wingtip tanks and you're good to go.
Old 06-24-2008, 11:28 AM
jmartinez443 jmartinez443 is offline
Originally Posted by rrnixonjr View Post
Any guesses what this is?
It's a Pratt and Whitney WASP 4360. See description from Wikipedia below.
Pratt & Whitney R-4360
From Wikipedia, the free encyclopedia
Jump to: navigation, search
Pratt & Whitney R-4360 Wasp Major (sectioned)
Pratt & Whitney R-4360 Wasp MajorThe Pratt & Whitney R-4360 Wasp Major was a large radial piston aircraft engine designed and built during World War II. It was the last of the Pratt & Whitney Wasp family and the culmination of its maker's piston engine technology, but the war was over before it could power airplanes into combat. It did, however, power the last generation of large piston-engined planes before the jet engine and turboprop took over.
It was a 28 cylinder four-row radial engine with each row slightly offset from the previous, forming a semi-helical arrangement (as can be seen in the photograph), to facilitate cooling of the successive rows of cylinders. A mechanical supercharger geared at 6.374:1 ratio to engine speed provided forced induction, while the propeller was geared at 0.375:1 so that the tips did not reach inefficient supersonic speeds.
Although reliable in flight, the Wasp Major was maintenance intensive. Improper starting technique could foul all 56 spark plugs, which would require hours to clean or replace. As with most piston aircraft engines of the era, the time between overhauls of the Wasp Major was about 600 hours when used in commercial service.
Engine displacement was 4,362.50 in? (71.5 L), hence the model designation. Initial models developed 3,000 hp (2240 kW), but the final models delivered 4,300 hp (3200 kW) using two large turbochargers in addition to the supercharger. Engines weighed 3,482 to 3,870 lb (1,579 to 1,755 kg), heavy but giving a power to weight ratio of 1.11 hp/lb (1.83 kW/kg), matched by very few engines.
Jorge Martinez
QB 8A Fuse. Just battled the ^%&@ing gear weldments. Now I can move on.
http://www.rv8alog.com
Old 06-24-2008, 01:15 PM
This may be the same "corncob" engine used on the old B-36? One of my old Air Force buddies told me that it usually took two days just to change the spark plugs on one engine. That include the time to set up the maintenance stands and crane, pull the cowl, R & R the plugs, re-install the cowl, and move all the stands away from the plane. I believe that the engines on a B-36 stood about 30 feet off the ramp? The photo doesn't give a true representation of the actual size of this engine. Four banks of 9 cylinders is a lot of engine.
Old 06-24-2008, 01:24 PM
??? Was it 4 rows of 7 cylinders or was it 9 cylinders? I thought it was 9?
Old 06-24-2008, 06:00 PM
osxuser's Avatar
osxuser osxuser is offline
4 rows of 7, 28 cylinders total. 28 cylinders =56 spark plugs, 7 mags I believe (4 cylinders per...) and 3600 HP?
RV4 wing in Jig @ KPOC
RV7 emp built
Old 06-24-2008, 07:31 PM
Webb's Avatar
Webb Webb is offline
Default Spark plugs
if the spark plugs are usable, the massive ones are 16 and the fine wire are 36.
If you pulled the plugs and sold the engine for scrap, you're already ahead on just the plugs.
Are they fine wire??
Webb Willmott
Jackson, MS
N32WW
Old 06-24-2008, 08:25 PM
rrnixonjr rrnixonjr is offline
Post Ongoing modifications to my Wasp 4360 RV4.
I kinda liked Webb's idea. Instead of relocating my wing I will redo my structure to something like this. Wonder if Van will approve of it.
Old 06-24-2008, 09:44 PM
Webb's Avatar
Default Strap it on
Just strap that puppy on your back and let-r-rip.
Webb Willmott
Jackson, MS
N32WW
Old 07-01-2008, 01:24 PM
Mr. Mikey Mr. Mikey is offline
Just use the front cylinders.
Then use the others to hold oil, fuel, luggage, tools, spare parts, life raft, survival kit, lunch, passengers......
Old 07-01-2008, 01:39 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
Originally Posted by Webb View Post
Hmmmmm.... I wonder where my OSH camping gear would go?
I am really getting tired of my 1+ hour commute to work... I think you may have just solved the problem.
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
