06-23-2008, 11:57 AM
How many hours before starting?
I'm a 40 year-old student pilot (about halfway done) and have pondered the question of whether it would be better to build or continue to rent.
Considering the RV series to be the most cost-effective and best looking kits on the market (IMHO), I am strongly leaning towards building.
If I decide to build I will, like most others who started their projects, take it slow. I have absolutely zero experience with sheet metal working and want to do this as correctly as I can.
Now, here's the question. Should one have a certain amount of flying experience before building their own aircraft? I can't tell you how I love to be in the air. It's freakin' awesome! Took a small x-country this weekend and wished that I could go back in time and made this my career!
I believe I have the passion to build. Just wanted to know if this is something that I should pursue immediately after obtaining my certificate or should I wait until I have a couple hundred hours in the books?
Mike
06-23-2008, 12:00 PM
I say start building NOW if finances and time will allow. There is no reason to wait otherwise.
Scott Card
CMW E-Lift
06-23-2008, 12:07 PM
Have a couple hundred hours before you build your panel or decide whether you want to go fixed pitch or constant speed. You don't really know what you want in those regards until you have a little flying under your belt. These are two parts of the build that are particularly expensive, so you don't want to waste your money.
That said, there's no reason not to start building now. Nosewheel/tailwheel will be your first big decision, but that's a ways off down the building road. (There too, experience flying one or both will really help you make an informed decision.)
Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
06-23-2008, 12:13 PM
I'm not sure I agree that a couple of hundred hours is necessary. I have about 130 hours, and at my current rate (flying rentals once a month) it would take me years to get to 200. I plan on breaking 200 hours in my RV! I do feel now that I have enough to make informed choices about my panel and prop.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
06-23-2008, 12:15 PM
I did this very thing. I built my RV7A then got my PPL. I would recommend you finish your PPL then build. This is just a question of time managment. I do not feel you can work, build and learn to fly at the same time. Finish up your PPL then build.
06-23-2008, 12:27 PM
Thanks for the quick reponses.
I'm definitely going to wait until after I get my certificate before purchasing an empennage kit.
The answer to the questions you pose is rather dependent on if my wife intends to fly with me. Right now, she says no. I solo'd in a PA-28 161 (Warrior II) a couple of weeknds ago and her comment to me is that the plane looked like a toy. Can't imagine what she'd think of an RV! I hope to meet a RV'er down the road and have my wife take a look, perhaps even get her to sit in one! I think that will either make or break her decision.
If she decides to fly with me, then I'd like to build something that would accomodate two side-by-side and some baggage, like a 9A or even a 10 (if the kids would go). If she's dead-set against flying with me, then I'd like to build an 8/8A as limited aerobatics is something I've always wanted to do.
Lot's of decisions....
06-23-2008, 12:42 PM
I don't see any convincing reason to wait. Go ahead and get the emp kit now and see how things work for you. Building is going to take a lot longer than getting your PP cert, so you may as well start the process now.
The 7 has both side-by-side seating AND limited aerobatics! Hopefully you can change your wife's first impression of light aircraft.
David
06-23-2008, 01:05 PM
I started building with zero flight time. There are several others also who have done this.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
06-23-2008, 03:02 PM
Builders class
Mike
Hi Mike,
I'd suggest that you take some kind of a builders class to introduce you to some of the basic skills that you'll need. I'm sure that some folks will recommend somebody (hopefully in your area).
Take care,
/\/elson
RV-7A Tip-Up
NW Austin, TX
06-23-2008, 03:09 PM
Build the plane YOU would like to fly. If you are like most pilots, you'll be solo 99% of the time. When the kids and familiy want to ride along, rent.
My $.02
PS: I vote for starting your build now. You'll know what you want by the time you get to the expensive bits.
Jorge Martinez
QB 8A Fuse. Just battled the ^%&@ing gear weldments. Now I can move on.
http://www.rv8alog.com
