Old 06-21-2008, 03:24 PM
Steve Brown Steve Brown is offline
Default Engine Cleaning???
I have an annual condition inspection coming up and I think I need to clean the motor as part of it.
How is this done in a "eco-friendly" way?
My home port, PAO, is about 100 feet from the bay and 4' MSL
Steve Brown
N598SD - RV9A second owner
O-320, 9:1 pistons, Catto 3 blade
KRHV - Reid Hillview airport, San Jose, CA
Old 06-21-2008, 03:43 PM
nucleus nucleus is offline
Talking Inside or Out?
Your may want to specify whether your intention is to clean the inside or the outside of the engine?
Dr. Hans Conser
Bozeman Chiropractor
RV-6A 195 Hours, up for sale soon?
Old 06-21-2008, 04:00 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Well, if he is worried about it getting into the bay, my money is on "outside."
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-21-2008, 06:34 PM
Jim Harchanko Jim Harchanko is offline
Engine cleaning using a spray wand (Aircraft Tool and Supply, item no. 37CB) that sucks Mineral Spirits with high pressure air and splashes the solvent on the engine works well. Not a lot of solvent is used and it can be absorbed with newspaper or paper towels. Much of the solvent will evaporate but this is what happens when Mineral Spirits is used to thin paint. This is what I have observed A&P's using and I have done it this way with good results.
Old 07-03-2008, 06:04 PM
Default Thanks Jim
This looks like the way to go. Palo alto is fanatic about pollution.
Steve Brown
Old 07-03-2008, 09:20 PM
glenn654 glenn654 is offline
Get a can of Gunk or equivalent...does a good job, water-based but don't blast water on the mags or alternator very heavily...you'll be fine.
Glenn Wilkinson
