06-20-2008, 09:27 PM
Heat valve installation pix wanted
I need to see some images -- as many as possible -- from anybody who has the EPM Heater Valve 1A installed on an RV-7.
Please post a link or email me at bcollinsrv7a@comcast.net
thanks
06-20-2008, 09:43 PM
Bob-
If you can, exchange the 1A for the 1B. The 1B has the cable control on the inside of the cabin just like the aluminum one Van's sells. With the 1A, you have to have a cable penetration in the firewall making it more complex.
06-20-2008, 09:56 PM
Yeah, I probably will; I'm sure Avery will take it back. Thought I ordered the firewall side version, but I guess not. Just another P-I-T-A thing to do this weekend.
06-30-2008, 11:30 AM
When I was searching for EMP valve I found they are quitting from business.
http://www.epm-avcorp.com/
So if you have anything happening with them I would act quickly now.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
08-08-2008, 04:59 AM
EPM will re-emerge as Plane Innovations
I received my heat box from Paul Bowmar. If you tried the old website it has a contact number for Paul. He still has some inventory left from the old company. One of the partners suffered some health issues so the company is folding but Paul said he will go forward alone under a new company called Plane Innovations once he gets everything in order legally and inform us on the forum once that happens.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
10-05-2008, 10:27 AM
I've got the 1b. Now I need some more clarification on the orientation of it. hence, I'm still looking for pictures.
The way I've got it envisioned now, given where the hole is on DWG 19, one of the bolts that holds it in place is going to go through the angle on the firewall, kinda close to a rivet.
I could flip it around, I suppose. It'd be easier to make a doubler plate for the inside of the firewall.
Curious to how folks have mounted this.
10-05-2008, 10:40 AM
Ah. never mind. I found what I needed here.
Richard Horan's site, by the way, is one of the most underrated construction sites for RV-7 builders.
