06-19-2008, 06:07 PM
232 Output question
Can you run the R232 line from your GPS into both the autopilot and the engine monitor at the same time? Or is the signal attenuated such that it won't work for both units.
Autopilot (Digitrak) is manditory, Dynon EMS is optional and I don't have a glass panel.
Only reason for asking is fuel calculations.
Now's the time to cut long and store, or crimp and attach.
Webb Willmott
Jackson, MS
N32WW
06-19-2008, 06:11 PM
Crimp and attach. Common practice to tie 2 or 3 devices (receive lines) on the same transmit line. As long as everything speaks the same protocol and baud rate, your golden.
06-19-2008, 06:12 PM
I've done this from my Garmin 396 to the following devices:
1. Dynon D10A
2. JPI FS-450 Fuel Flow
3. TruTrak Pictoral Pilot
Works great. I haven't had any problems with any of these reading from the same signal wire. Someone else may come along and tell me that I'm crazy for doing it this way, but I figure that since the garmin is the only one writing signal on the wire and the other 3 do only reads, it shouldn't matter much.
Aaron Sims
RV-10 (2015 Bronze Lindy)
RV-6A (sold)
Home Field: Mallards Landing (GA04)
Locust Grove, GA
06-19-2008, 06:19 PM
Speak same
Ok - Garmin 430, Digitrak II, and Dynon EMS. Golden??
Webb Willmott
Jackson, MS
N32WW
06-19-2008, 06:44 PM
You should be in great shape. Check the manuals to be absolutely sure.
06-19-2008, 07:47 PM
things that make you go hmmmmm......
Somthing tells me that this is one of those.......you know it's OK but hold your breath when you turn it on.......grit your teeth...and hope for no smoke....
Based on the fact that the R232 is an output line and the AP and EMS are just receiving input, it shouldn't be an issue. Worse case.....430 output too low and I cut the EMS lead. I don't think that is going to happen since the leads are so short anyway.....
As always, I'll report back later when I get the guts to flip the switch.......
Webb Willmott
Jackson, MS
N32WW
06-19-2008, 08:07 PM
Check the manual
Webb,
I agree all the 232 lines can be connected together and work, with notes from others, but....
I have the dynon D10A not the EMS so this may not apply.
Dynon updates the D10A vis the RS232 input line and it is required to disconnect the RS232 line from everything else while updating.
So read the manual as it pertains to updating and the associated wiring before you jump into a final configuration.
Hope it helps.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
06-19-2008, 08:28 PM
VAF Moderator / Line Boy
Originally Posted by Webb
Something tells me that this is one of those.......you know it's OK but hold your breath when you turn it on.......grit your teeth...and hope for no smoke....
There's no worries about smoke Webb - it's common and accepted practice to split the serial line to multiple devices. the reason people say to "check the manuals" is for the protocols - the signal LEVEL will be just fine, but you'll need to make sure that all the devices have a common language that they will understand. Most common GPS's put out NMEA183, so MOST devices understand that. But some companies think they're special and will only understand their own proprietary code. So you'll have to open up all the manuals and compare data format tables to find what is common.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Originally Posted by Bob Martin
Webb,
Hope it helps.
According to Dynon, if you only have an EMS-D10 without magnetic heading from an EFIS, the HSI page will not be functional. You should connect a the R232 transmit line connection from the GPS to pin 19 on the Dynon. It will give you on fuel endurance info (range, MPG, etc..) on the fuel page and GPS info (track, ground spreed, course, etc..) on the HSI page. There is no need to break the connection when doing PC updates. You just hook up the serial port to the EMS-D10 and away you go. I'm hopeful that I won't have to do updates, however the thought of having programed checklists is preferable.
Webb Willmott
Jackson, MS
N32WW
06-19-2008, 11:23 PM
Will check out the code
Paul
Like the "secret" handshake - I'll check out the code to make sure that everything shakes hands. I'm probably good to go.
The "smoke" was one of those expressions. I'm not really worried about that, just expressing the proverbial "keeping my fingers crossed".
Webb Willmott
Jackson, MS
N32WW
