06-19-2008, 01:12 PM
So is this just too anal ?
I decided to just prime the contact areas where the ribs meet the skin and hated to just let the overspray fall where it may, so I used the soldering iron trick on the inside of the skin and used the remaining vinyl for masking. Peeled it off after the primer was dry and was pleased with the results. Didn't waste too much time in the process.
http://www.weflyforfun.com/p1010052.jpg
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
06-19-2008, 01:15 PM
That's what I did; works great!
06-19-2008, 01:38 PM
Whatever does it for you  .
RV4 wing in Jig @ KPOC
RV7 emp built
06-19-2008, 01:56 PM
Anal - perhaps. But it looks good and it saves weight. Granted, you're probably the only one that will ever see it!
06-19-2008, 02:34 PM
Hmm... why remove it at all? Would you really even need to remove the protective plastic on the internal pieces ?
* I don't build  just a passing thought *
06-19-2008, 03:07 PM
I believe the answer to this is a resounding, "YES!" I've removed that plastic to find some light corrosion under it. (Easy to take care of but...) You're better off removing the plastic coating. (besides, every ounce of weight removal helps.)
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
 RV-9A Firewall Forward
[Engine purchased]
06-19-2008, 04:39 PM
[quote=speed;232344]Hmm... why remove it at all? Would you really even need to remove the protective plastic on the internal pieces ?
* I don't build  just a passing thought *[/QUOTE
I feel his idea is to remove the plastic for sure. If you don't remove the plastic there will be corrosion!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
06-19-2008, 05:35 PM
Yes, that is anal. Then again, whatever floats your ship.
Jorge Martinez
QB 8A Fuse. Just battled the ^%&@ing gear weldments. Now I can move on.
http://www.rv8alog.com
06-19-2008, 06:45 PM
It's exactly what I did.
06-19-2008, 07:00 PM
Ha!
I'am having dejavu. My dad and I did the exact same thing a couple days ago! I guess i shouldn't call him 'overkill' as much.
JRRVFLYER
Working on Emp.
