Old 06-17-2008, 11:40 AM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default FLAP RIGGING questions
Wings are on and now installing flaps. 9a, anyone ahead of me able to provide either a good builders log site or comments on the following.
1. brass bushings for flaps need to be cut from .25 down to .156 Any easy ways to cut that small a part that size? Uggh Must be easier way than a hacksaw?
2. va256 flap push rod length. We have made the fues holes to fit, but are having trouble getting the right length to give us the correct travel. Should the flaps be in line with the wing and then down max 45? what do folks use to get accurate angle measure and how many times did you have to take on and off???
Today is just one of those days were it appears we forgot how to build. Looking at the rod, taking it all apart, cutting, putting all back together and the stupid things just doesnt seem to be getting there. Scanned Dan C and a few others sites and cant find good details. Any help would really make today a better day!
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 06-17-2008, 11:55 AM
9Driver 9Driver is offline
Mine has been flying for 3 years, but I do not remember cutting the bushings shorter. Also Max flap down on my 9a was 32 degrees. Seems like I just pressed the bushings into the wing bracket s they were.
Old 06-17-2008, 11:59 AM
BillC BillC is offline
Never Mind.
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 06-17-2008, 01:45 PM
N941WR's Avatar
N941WR N941WR is offline
The way you are supposed to adjust the flaps on the -9 is to set the aileron position using the long stick attached to the end wing rib. Then the outboard ind of the flap matches the inboard end of the aileron. The flaps will probably not touch the belly of the plane when this is done, per Van's.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
