Old 06-16-2008, 05:51 PM
RV6_flyer's Avatar
Default Unison service Bulletins now Lycoming Mandatory Service Bulletins
In May, Unison issued Service Bulletin SB2-08 for Slick 4300/6300 and LASAR 4700/6700 Mags. It affects Slick and LASAR mags with serial numbers 0610XXXX through 0804XXXX for the breaker point cam. Eleven days later, they came out with SB3-08 for the same mags with serial numbers 0409XXX and up with respect to the carbon brush.
June 3, 2008; Lycoming now has two Mandatory Service Bulletins for the above two Unison service bulletins. I cannot share my Unison subscription or my Lycoming subscription but Lycoming publishes some of Mandatory Service Bulletins on their web site so everyone can get the info for free.
http://www.lycoming.textron.com/support/publications/service-bulletins/pdfs/SB584.pdf
http://www.lycoming.textron.com/support/publications/service-bulletins/pdfs/SB583.pdf
The cam is made of plastic and retails for sixty cents. The carbon brush retails for just under $6.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-16-2008, 06:21 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Thanks
Gary, Thanks for posting this.
Gotta go check the data plates
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-09-2008, 02:43 PM
Geico266's Avatar
Geico266 Geico266 is offline
Well Mike....
Did you win the Lotto?
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 07-09-2008, 02:44 PM
Geico266's Avatar
Has anybody wondered why the SB number don't match up, but are concerning the same SB? One is a revision of the other, but the numbers don't match.
Old 07-09-2008, 03:24 PM
Mike S's Avatar
Senior Curmudgeon
Originally Posted by Geico266 View Post
Well Mike....
Yep, mine are not in the date/serial number range.
Got lucky and dodged the ECI cylinder bullets also.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 07-09-2008, 03:28 PM
N941WR's Avatar
N941WR N941WR is offline
Nope. I've got duel P-mags. You would never catch me running those old mags, they could kill ya!
Sorry, I just couldn't resist after all the grief I was given a year ago about the P-mags. (Now with 165 trouble free hours!)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-09-2008, 04:30 PM
Geico266's Avatar
You are a charmed man! I'm following you!
Old 07-12-2008, 01:13 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
I'm clear of this one as well as the cylinder recalls.
Not so lucky with the sump, but it is working well.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 07-13-2008, 09:36 AM
Steve Steve is offline
Default not the same SB
One SB concerns premature wear of the breaker point cam. The other is about premature wear of the carbon brush.
A simple verification of your ignition timing takes care of the breaker cam SB. A change of more than 4 degrees from the original setting indicates cam wear and a need to replace it. Recheck periodically per the SB.
The other SB involves disassembly of the mag for visual inspection of the carbon brush, the contact arm, a buildup of carbon dust, and damage from arcing. Recheck periodically per the SB.
Notes: Your 1 year warranty may still be in effect. However, the replacement parts will be the same as the original items as new parts are still in development. One SB concerns mags built starting in 2004. The other goes back to 2006. Unison issued the SBs in May. Lycoming did a CYA by making them Mandatory SBs in June.
I have 50.8 on my -9A. My A&P said to:
1. verify mag timing. (done and no change from 25 deg BTDC)
2. keep flying.
3. order replacement parts anyway because they're cheap.
4. He and I will inspect and replace the suspect parts, if req'd, when they arrive.
Steve
Old 07-13-2008, 12:08 PM
vlittle's Avatar
vlittle vlittle is offline
Spoke with Bart Lalonde at Arlington yesterday re the SB.
Right now, if you replace the brush, you will have to reinspect according to the intervals in the bulletin. He's awaiting a "permanent" fix from Unison, so that you can eliminate the requirement for periodic inspection.
If you have an AeroSport engine, and need more info, call Bart.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
