Old 06-16-2008, 01:32 PM
mcattell mcattell is offline
Default FPS Flap Positioning
I am considering using one of the FPS Flap Positioning systems for flap deployment. I also was planning on installing a Ray Allen position sensor that would connect to the EFIS for flap position indication. Does anyone have both of these installed in their airplane? I don't have either yet and am wondering if there's room to attach both sensors to the flap motor shaft.
Old 06-16-2008, 04:09 PM
shuttle's Avatar
shuttle shuttle is offline
There's room for both if you drive the Ray Allen position sensor off the Flap Actuator Weldment rather than the Flap Motor Shaft.
Steve
Old 06-16-2008, 04:15 PM
scard's Avatar
scard scard is offline
I agree there is plenty of space. I have the FPS and really like it.
Scott Card
CMW E-Lift
Old 06-16-2008, 07:48 PM
yakdriver yakdriver is offline
Why go to the trouble and complexity. Count out three seconds(one one thousand etc) and that's half flap count out four more and that is full flap. Plus all you have to do is look over your shoulder and see how far they are down. You are just adding more build time, more money, more weight and more chances for something to fail. KISS is good. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 06-17-2008, 01:00 AM
Steve Sampson Steve Sampson is offline
Default Or an OFPSS system?
Why not use something like my OFPSS? Its an optically driven system that presents some significant advantages and is lighter and faster responding.
Steve
G-IKON Build log here , or Index to blog here.
RV4 #4478 - Flying since 16th June '08. First flight video here.
Circuits at my 1000' strip.
Old 06-17-2008, 01:27 AM
Default All good suggestions
Thanks for all the good suggestions. In my 40 year old Cessna I have a manual switch and round gauge with a needle. It works most of the time but I do have to tap the face of the gauge quite often when the needle sticks. I was hoping to have better on the RV but I suppose it is harder to easily see flap position on a Cessna. Then there's the whole issue of eyes out in front of the cockpit. I'll have to comtemplate this some more. This isn't the first time I've been accused of liking my electronic gizmos too much.
Old 06-17-2008, 06:19 AM
Let me tell you about eyes out in front of the cockpit. Was at a fly in at a grass strip here in Idaho and a guy in a Cub on amphib floats was parked about 1500' from the departure end. He cranked up and didn't look right or left and just started to pull out on the runway. Another plane was on the take off roll and three people on each side of the Cub tried to get his attention. One brave soul leaped up on one float and finally got him to stop. There was less than ten feet to spare when the other plane went by.
You need to have your head on a swivel at all times especially in the pattern. It only takes a second to glance at your flaps so it is a non issue. There are only three basic flap settings you need. Half flaps on downwind, full flaps base to final and 15 degrees for a short field take off that can be had by lining the flap up with the aileron in full down deflection. Any more than that and your working way too hard in the pattern.
Next project?
Old 06-17-2008, 11:50 PM
ge9a ge9a is offline
Yes, you do like your electronics, don't you!
Greg English
Beaverton, OR
RV-9A QB
