Old 06-16-2008, 12:50 PM
f1rocket's Avatar
f1rocket f1rocket is offline
Default Oil Pressure Switch - How Have you Connected It
This time around, I plan to install an Oil Pressure transducer switch so I won't forget to switch off my electronic ignition system again. Since the Van's catalog doesn't contain a picture of this device, I'm assuming it is big and round like the other pressure transducers. If so, I'm wondering how others have hooked it up to the transducer manifold on the firewall. I want to run just one oil line and that position will be taken up by the oil pressure transducer and it doesn't look like the oil pressure switch will fit on top, so how have other's done it? I'm sure there's some elegant way to getting this accomplished, but my brain can't seem to figure it out at the moment. Thanks.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 06-16-2008, 01:00 PM
Kahuna's Avatar
Kahuna Kahuna is offline
Assuming your only installing the switch to remind you to master off, Id recommend hooking up the idiot light to alternator. Most have em now coming from Vans or NAPA. AND you dont have oil line to transducers to deal with for future failure points.
Since most folks are running more modern engine monitors, oil pressure switches have become a thing of the past. More things to go wrong for no value add.
If my first assumption is incorrrect, then forget everything I just said.
Best,
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 06-16-2008, 01:33 PM
flybill7 flybill7 is offline
Randy,
Here are some pictures of how I did it. I had to put a spacer under the transducer so the pressure switch would fit on the side.
http://www.pilotbill.com/Dec07/Wiring_21Dec07.htm
... Bill
Bill Cloughley
Severna Park, Maryland
RV-7 Flying (1,400 hours)
Old 06-16-2008, 01:48 PM
647jc's Avatar
647jc 647jc is offline
Another way.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 06-16-2008, 07:34 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
I used one of those dual-output VDO senders (360 025) with a pressure switch (for an idiot light) as well as the resistive gauge output. I then used the pressure switch to turn on a little cube relay to run my Hobbs meter on the NC contacts and a big, fat red light in front of my nose on the NO contacts. Yes, I have an EFIS with engine monitor, but nothing gets your attention like a BIG RED light. The nice thing about using the dual-output VDO sender is simplified plumbing.
Not sure how to post a PDF file, but if you want a copy of my schematic emailed to you, send me a PM.
Heinrich Gerhardt
RV-6, flying
Old 06-16-2008, 08:56 PM
Rivethead Rivethead is offline
You might want to take a look at the one from B&C.
http://www.bandc.biz/cgi-bin/ez-cata...1X358218#s8012
Old 06-17-2008, 05:58 AM
f1rocket's Avatar
Best,
Thanks Mike, but here's the problem. The Lightspeed Electronic ignition is connected directly to the battery bus so it bypasses the Master switch and the primary and essential busses. I will have one Magneto switch and one EI switch. When I shut down, it is sometimes easy to forget to turn these two switches off without some kind of indicator. I have a alternator light that is connected to the alternator controller so if I leave the master on, this light shines bright. I've looked at this a dozen ways and I don't see a way to do it without a oil pressure switch, but I'd love to hear and see more ideas.
647jc, that's a good way to do it, but my third manifold hole is being used for manifold pressure. I've found it a convenient way to transition from -4 hose to 1/8" copper tubing to feed the manifold pressure senders.
I still think I need to find a way to plumb the sensor to the second hole on the manifold where the oil pressure sender is plumbed.
Randy Pflanzer
Greenwood, IN
Paid through 2043!
Old 06-17-2008, 06:01 AM
f1rocket's Avatar
Originally Posted by flybill7 View Post
Randy,
... Bill
I think that's the ticket. Thanks Bill.
Randy Pflanzer
Greenwood, IN
Paid through 2043!
Old 06-17-2008, 06:26 AM
uk_figs's Avatar
uk_figs uk_figs is offline
I plumbed the same as Bill, in addition to switching on the Hobbs I have the Dynon EFIS/EMS alarm wired into the same circuit so the red light remind me to shut off the master, indicates low oil pressure and also indicates system alarms. Acts like a master caution/warning.
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 06-17-2008, 06:30 AM
Rockyjs Rockyjs is offline
Randy,
My solution was pretty similar to Bills, instead I used a 45 degree street elbow and an inexpensive oil switch. It's wired to my Ebus, so I have a backup to the main bus EFIS/EMS indication.
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
