...or it can power the Dynon serial-parallel converter module...
The GTX-320 needs a parallel input for altitude data, and most EFIS units output serial data.
This saves a fuse/breaker, since if the transponder fuse blows/breaker pops, it doesn't matter if the converter is powered or not....
gil A
