I set the seed position on mine before my first flight by using a portable automotive GPS that displayed lat and long along with current UTC time. It worked fine. The manual says the seed position is not required, but it can take up to 20-30 minutes (I think) for the unit to "find itself" without it. Just pull the airplane out where it has a good view of the sky and wait... and wait.
I was recently talking to customer service about something else and it came up that if you shut down with a master switch instead of the unit's power switch it's possible to lose the seed position, requiring re-entry or self-acquisition (time consuming). Maybe that's what happened?
If you can't get it to work or have other questions, I have found John Hendrickson at Garmin tech support to be very helpful- (800) 525-6726, ext 3016.
Hope this helps!
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
