Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 06-12-2008, 03:38 PM
BlackRV7's Avatar
BlackRV7 BlackRV7 is offline
Default Disassembling a Constant Speed Hub
I've got the back of my HC C2YR 1BF A sub hub but the front obviously has a trick to it I'm not seeing.
Anyone able to lend some knowledge I obviously don't have, I need to get these bent up blades off so I can send the hub in for inspection.
Dana Overall
Richmond, KY i39
http://www.DanaOverallCPA.com
Repeat offender, RV-10 emp
Builder/former owner, RV-7, "Black Magic" Flying
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
VAF #993
Old 06-12-2008, 05:51 PM
joeboisselle joeboisselle is offline
Dana,
I didn't tear apart the prop I got from you =) and I'm not a Hartzell specailist, but I play one on VAF... the front cap needs to be unscrewed. There are four bolt holes on the front that requires either a special wrench or a homebuilt one matching those four holes. After removing the cap, you can remove the piston, the spring, keepers and oil supply tube. Don't worry too much about that spring, it should only pop up about an inch. Once the piston is removed, the blades should just fall right out. Carefull to watch in which order everything comes out, and be ready to catch those ball bearings when the blades come out. Other than that, easy as pie. Good luck buddy.
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
Old 06-13-2008, 07:00 AM
BlackRV7's Avatar
Originally Posted by joeboisselle View Post
Dana,
I didn't tear apart the prop I got from you =) and I'm not a Hartzell specailist, but I play one on VAF... the front cap needs to be unscrewed. Good luck buddy.
Hah, you want to trade props
Are you saying the four thread inserts into which the four bolts go for the front spinner plate need to come out along with the low pitch stop? If so, how in the heck do I get those threaded inserts out?
Back to my original question......you want to trade props Actually I am looking at my new HC-C2YR-1BFP/F7497-2 blended prop FedEx delivered yesterday after my Tuesday evening post asking if anyone wanted to trade Hartzell spots. I should have also bought a lottery ticket that day.........
Dana Overall
Richmond, KY i39
VAF #993
Old 06-13-2008, 09:04 AM
[quote=BlackRV7;230912]Hah, you want to trade props
QUOTE]
That's how ya do it, you shouldn't have to remove the inserts though, i simply made a long handled tool with those 4 holes drilled at one end, bolted it on to the hub (after removing the low pitch stop of course) and off it came. I can post pictures later if this is still clear as mud.
Trade props? Nah, I worked so hard to get this one!
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
Old 06-13-2008, 09:20 AM
breister breister is offline
Hate to rain on your parade, but are you aware that Hartzell says the hub is to be decommissioned following a prop strike? I presume that is what happened since you say, "bent blades..."
Old 06-13-2008, 10:00 AM
osxuser's Avatar
osxuser osxuser is offline
Thats why we fly experimentals. If it's not cracked, it's not cracked.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 06-13-2008, 12:22 PM
BlackRV7's Avatar
[quote=joeboisselle
Trade props? Nah, I worked so hard to get this one![/QUOTE]
Better draw me a picture..........I'm having vapor lock.
Man, it was easier getting my new prop than it was to get that one to you cross country. Geez
Dana Overall
Richmond, KY i39
VAF #993
Old 06-13-2008, 01:02 PM
I took my MT hub apart last fall but had the cell phone going and connected to a tech rep who talked my though it....the first time you may need some help.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 06-13-2008, 02:55 PM
wow imageshack is terrible! The photo below (you can see it better if you click on it) is an unused hub "cylinder" if you will, and a quick build hub cylinder removal wrench thingy I made this morning for pictures only, my good one seems to have walked away. You might start with reassembling the rear half of the hub with a few bolts to hold it in place while you take apart the front, makes things go smoother.
Application of said wrench to assembled hub "cylinder" with the assistance of a few bolts holding wrench to hub, along with more assistance of people perhaps holding blades in place... a good push in a counter-clockwise (looking twards the prop, yes lefty loosie) will give a final result of a removed hub. There's oil inside, be prepared for that too.
I'm on an extended extention of a long lunch break I'll go snap some more pictures of the inside of a hub and post them up asap, so long as no one notices I'm not at work.
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
Old 06-13-2008, 03:32 PM
BlackRV7's Avatar
Default Duh
It unscrews.........mission accomplished by putting the four bolts back in and a big ol wrench between them.
Thank ya,
Dana Overall
Richmond, KY i39
VAF #993
