Originally Posted by f1rocket
Do you need the extra performance because of where you're located?
Definately not.
If I don't change locations the next decade, it would operated from a 10K feet runway at 170 ft MSL. There are some nice fields around the country (Norway) which sort under "short&high&obstacles" but nothing that doesn't scare the 172s away.
Comfortable, swift (relative term), economical cruise is perhaps my top pri's.
Much of it depends on what you can afford.
Exactly, hence my budgets. At some point in the project my wallet would make the decision for me and having as much info as possible on options can only help. The replies so far have been excellent for putting thought to the numbers, thanks all!
