06-09-2008, 04:40 PM
VAF Moderator / Line Boy
Garmin 430 "Mem Bat Low"
Hmmm....wonder if anyone else has seen this - I cranked up the GNS 430 today and got a "MEM BAT LOW" message. I checked the manual when I got a chance, and it says that I have to have a dealer replace the battery. Well that makes sense, but I got a couple of questions....
1) Has anyone else had this done? Is it a "Local" repair? How much did it cost? (I am hoping this isn't a "Return to garmin for their $700 flat rate repair" deals...)
2) Anyone know how long from the first message appearance to a loss of memory? In other words - does this require immediate action, or do I have a few weeks or months?
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
06-09-2008, 04:48 PM
fugio ergo sum
Originally Posted by Ironflight
...I am hoping this isn't a "Return to garmin for their $700 flat rate repair" deals...
My personal experience is that Garmin can be very flexible in dealing with polite and informed customers that have an early failure, even if the unit is well out of warranty.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
06-09-2008, 06:42 PM
Hummmmmm
Sounds like a 3volt battery or something like that. If out of warrenty..I would open her up and change it my self....
06-09-2008, 07:47 PM
Sanyo Lithium cell # CR14250SE with solder tabs
This is from Bob Newman of TCW Technologies
http://www.tcwtech.com/
06-10-2008, 05:10 PM
Thanks!
Thanks guys!
I had a talk with Garmin today, and the 430 is on it's way overnight to Kansas for a quick turn-around repair and overall check-up. I liked th links posted for a DIY fix, but in my conversation with Garmin, it was pointed out that the battery should have lasted much, much longer - and that frequently, field shops will replace the battery, only to eventually find that the charging circuit was the problem. Since I fly IFR with the unit, I decided discretion was the better part of valor in this case, and decided to let them do their magic....
Paul
Paul F. Dye
06-10-2008, 06:00 PM
hummmmmmm
Well in that case,,,,,,,,......good choice..!
06-11-2008, 10:42 AM
Hello Paul...
Thanks guys!
Paul
Please let us know how much the charge for this when you get it back.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
06-18-2008, 01:42 PM
It's Back!
I got my 430 back from Garmin yesterday and it slid right in and fired up without a problem. Latest software loaded, and the paperwork said that they "repaired the main board and also repaired an unreported problem in the keypad interface". They got the unit on Thursday, and shipped it Monday, and the total charge was $0.00 - can't ask for much better than that!
One note of interest is that when they loaded the new software, they saved my user waypoints, but not my stored flight plans. It was no big deal for me, because I only had a few plans saved anyways, but I can't figure out why one thing would survive the jump, and the others didn't....
Thanks to Garmin for the speedy turn-around - I hate holes in my panel (even though I was adequately equipped with my #2 Comm and three other GPS's.....  )
Paul
Paul F. Dye
11-20-2008, 10:47 PM
Bad keyboards??
?and also repaired an unreported problem in the keypad interface"
I am wondering if there is a known problem with Garmin GNS 430 keyboards, because I am experiencing intermittent keys on mine that appear to be getting worse?
RV8 "Gladder's Gal" #80707
Superior IO360 B1B 193 HP, Whirlwind 151-69"
IFR-Dual Cheltons, Crossbow NAV 425EX
Garmin 430/SL30/330 Mode-S w/ traffic
Ryan 9900B TCAS, WSI AV300, S-Tec 55X
Searey 80 HP
