Old 06-08-2008, 09:05 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Fiberfrax on interior firewall
So yesterday, I spent most of the day covering the cabin side of the firewall with Fibrefrax http://www.aircraftspruce.com/catalo.../fiberfrax.php
I used the Fiberfrax cement as the adhesive.http://www.aircraftspruce.com/catalo...axadhesive.php
While I was applying the cement, I noticed that when it dried it was quite brittle. Now that I've got it all on, I'm concerned that the brittle nature of the dried product means that it will start cracking, fall off and make a big mess once it is subject to normal vibrations during flight.
Has any one else used these products? How do they hold up over time?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 06-08-2008, 09:32 AM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Ceramic fiber insulation is brittle and very "dusty". I personally, would not want it in the cabin. Having used 2300deg ceramic wool for my pizza oven, it is also considered a carcinogen. Your material may be different, but then again maybe not. Here is the MSDS for one type of fiberfrax.
http://www.fiberfrax.com/files/Fiber...MSDS-M0001.pdf
Make sure you look up the MSDS for the exact kind you have. Probably a good idea to seal it off with some other material if you decide to use it.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 06-08-2008, 11:20 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Typical Uses...
I believe it's usually used on the firewall side of composite planes (Rutans) and as a heat shield on the inside of composite cowls (our RVs) near hot engine components. I've seen them hold up well in these two applications.
Since it's usually bonded onto a fibreglas substrate, I'm not sure that your installation on the cabin interior bonded onto metal will stand up over time.
The best thing would be to contact the manufacturer.
It could be sealed with an epoxied layer of glass cloth, but that would not help with the long term adhesion to the stainless steel firewall.
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-08-2008, 01:55 PM
Rick_A's Avatar
Default What is good for the interior firewall?
Gil, after seeing your reply I decided to test the adhesion by removing a small piece. I wasn't terribly surprised when I found it came off quite easily.
I removed the rest of it - most of which came off pretty easily. Now I'm in the process of scrapping and cleaning off the places where the cement stuck well (not a lot but I'm sure it will take a few hours).
So this leads to the next question: What material is good for use on the cabin side of the firewall?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 06-08-2008, 02:11 PM
Bugsy's Avatar
Bugsy Bugsy is offline
Default cessna uses fibrefrax
Visited the Cessna plant last month, they used fibrafrax on the interior firewall for the columbia. Doesnt mean its the exact same as what you purchased but the concept isnt unreasonable either.
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
Old 06-08-2008, 03:27 PM
Ken Ken is offline
http://soundexproducts.com/
Ken
Old 06-08-2008, 05:18 PM
az_gila's Avatar
Smile But - composite materials...
...but..but.... isn't the Columbia fibreglas?
Fibrafrax works great on composite surfaces... and can be encased with a layer of glass on top of it...
It was the adhesion to stainless I queried.... and apparently, it doesn't...
gil A
Gil Alexander
Old 06-09-2008, 06:45 AM
rzbill's Avatar
rzbill rzbill is offline
Default I still plan to use it.
Once I saw the results of an RV inflight fire. (Not me, thank goodness). The stainless firewall did it's job, but the aluminum skin under and around the pilots feet (tandem RV) was GONE. I will likely put a layer of fiberfrax that starts up the firewall a couple of inches and is a continuous strip extending under the rudder pedals and rearwards about a foot or so. Planning on capturing it with a cover of some sort. Sound insul maybe.
Of course, I reserve the right to change my mind.
Bill Pendergrass
ME/AE '82
Old 06-09-2008, 07:27 AM
CNEJR CNEJR is offline
After looking at Soundex, and deciding their kit was a little pricey for me. I used a product called Dynamat. I read all the specs, did a burn test, etc. It came out quite well. They make a version for cockpits. I used two layers of 1/4 inch and sandwiched to layers of tin foil, one layer of bubble wrap between the layers between. When applying a torch to it, it self extinquished immediately, when removed. I used 3M adhesive to bond. Biggest job is to cut and fit cardboard templates for firewall sections. I found this setup to be very light.
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
