Old 06-07-2008, 10:00 PM
vbpiper's Avatar
vbpiper vbpiper is offline
Default Adel clamps on brake line of -7A
A search of the archives did not reveal an answer, so here goes. An A&P friend expressed some reservations about the tape/vinyl tube method of securing the brake lines on the gear legs of the -7A, citing concerns about durability of the tape as well as moisture under it on the legs. He suggested Adel clamps. My question is, is there room under the fairings for clamps, especially if I use the wood stiffeners?
Thanks.
RV-7A Finish kit
Renewed 8-14
Old 06-08-2008, 06:16 AM
yakdriver yakdriver is offline
There are thousands of RVs and other airplanes using the tape and vinyl tubing. Build on. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 06-08-2008, 06:32 AM
Mel's Avatar
Mel Mel is offline
Default Tape works...
My brake lines run through vinyl tubing and are taped to the gear legs. No problems for over 15 years. As far as moisture, the gear legs are covered with fiberglass which attach the wooden stiffeners so the tape is not on the steel leg itself..
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-08-2008, 07:53 AM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
I slid a short section of slit 3/8" air line around the aluminum tubing, faced the slit outward, wrapped a nylon tie wrap around it and used a Panduit gun to snug the tie wrap to the gear leg. Sorry I can't provide any engineering data, but it seems to work fine and has caused no wear on the inside of the gear leg faring, but it's only been on for three years...
RV7A-QB, RV-10
Old 06-08-2008, 07:59 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Will clamps eventually lose their grip on the taper? Just a thought.
Old 06-08-2008, 08:01 AM
Bob Brown's Avatar
When you install them with a Panduit gun, they show no measurable change after three years...still extremely tight.
RV7A-QB, RV-10
Old 06-08-2008, 09:02 AM
jsharkey's Avatar
Actually I meant the Adel clamps could slip down the taper - but I guess it could apply to the zip ties too. Perhaps it is why Van's ended up with tape - or perhaps they had a roll of tape handy!
Jim
Old 06-08-2008, 02:23 PM
vbpiper's Avatar
Default Thanks
Thanks for the input. Looks like I'll leave the tape/vinyl as is.
RV-7A Finish kit
Renewed 8-14
