Old 06-06-2008, 11:19 PM
ao.frog ao.frog is offline
Default How many quarts of oil on the new Superior sump?
Hi.
I've a Superior IO-360 and have replaced the "plastic" Sump with the their new alu-sump.
The oil drip stick was trimmed in the bottom end per instructions.
After this trimming, the 4-6-8 qrts marks on the dipstick are incorrect, so which markings scould I use now?
Maybe add 2 quarts value on the dripstick readings?
Thanks.
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 06-07-2008, 04:43 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
We were told "no change"... i.e. just read the dipstick...
Andy & Ellie Hill
RV-8 G-HILZ http://www.g-hilz.co.uk
Old 06-07-2008, 05:49 AM
n8zg's Avatar
n8zg n8zg is offline
Default Dipstick Markings
Alf -
I'd recommend you remove the original markings and make new marks.
I used a fine file to remove the majority of the marks, then chucked the dipstick in my drill. A little emery cloth made short work of what remained. Polished with a ScotchBright pad and cleaned it well to remove all traces of anything abrasive.
Neal George
Navarre, FL
CherokeeJet N9586J
RV-7 N8ZG (all the loose ends)
Continental Aerospace Technologies, Product Support
Old 06-07-2008, 11:23 AM
osxuser's Avatar
osxuser osxuser is offline
It should be the same.... it's a shallower, but wider sump at the bottom, the tapering to the same shape up top... right?
RV4 wing in Jig @ KPOC
RV7 emp built
Old 06-07-2008, 10:40 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Use the same marks. No change other than it's a shallower sump.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
