Used Kits
I purchased the tail kit from VANS and then bought the fuse and wing kits (both not started) from forum members (thanks guys!). In both cases, everything was in perfect condition. You will need to get a signed bill of sale from the original owner that shows their name and builder number, the date you purchased it, and the condition of the kit (i.e. "used kit, inventoried, but no assembly started" or something similar). Fax a copy to Vans requesting that it be transferred to your builder number (which they will have to establish if this is the first item you have purchased). The only area where this hurts you that I am aware of is Vans only sells their OEM engines to people who purchase all of the kits directly from them. However, very few people actually take advantage of that deal as most purchase engines from other sources. Good luck and welcome to the ride of a lifetime!
