Old 06-03-2008, 06:49 PM
chiefaponte chiefaponte is offline
Default Tank Sealer over Rudder Edge
While there are many threads regarding this issue, I have to ask the question. I have primed my inner rudder skins and at the point of finishing the trailing edge.
I have used Duplicolor self-etching primer with great adhesion.
Should I remove the primer?
I would think that the pro-seal is there to facilitate installation
What solvent would remove this primer the easiest?
Old 06-06-2008, 10:31 PM
jarhead jarhead is offline
If you properly prepped the pieces before priming (say that five times fast!), there's no need to remove any primer to apply proseal - it will stick just fine.
Ken
Helicopter mechanic (A&P)
USAFR KC-10 Boom Operator, on final approach to retirement
My RV-9/8/7 dream may be on life support, but it ain't dead yet!
