Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #11
Old 06-04-2008, 11:17 PM
ao.frog ao.frog is offline
Default Found it!
Hi again.
Thanks to this forum, I've found the bigger stud on the engine flange which will accept the bigger hole in the flywheel.
The M/T manual which came with the prop said: "mount the prop on the engine", so that didn't exactly make me any wiser...
Without this forum, my Quickbuild would definetely have turned into a Slowbuild a long time ago....
Thanks guys!
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
