Old 06-02-2008, 08:07 PM
danielhv's Avatar
danielhv danielhv is offline
Default HF HVLP Spray Gun...
Is this the one everybody uses?? Im planning on shooting AKZO someday, and who knows what else...
http://www.harborfreightusa.com/usa/...o?itemid=43430
It's on sale btw, regular = $59.99. Sale = $34.99
Old 06-02-2008, 08:38 PM
kenmorris kenmorris is offline
That's the one.
Old 06-03-2008, 11:42 AM
az_gila's Avatar
az_gila az_gila is offline
Unhappy Up....
... to $39.99 on-line to-day.
But our local store will honor the on-line price - better than around $60 in the store.
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-03-2008, 12:29 PM
rleffler's Avatar
rleffler rleffler is offline
gil A
That's a lesson I learned very early on..... Always take a print out from the web with you to the store. It's usually less expensive and they'll honor the pricing.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-03-2008, 02:20 PM
JBPILOT JBPILOT is offline
Default HF 43430
I just recieved another catalog today. $29.99 43430-ORAH. Page 48.
John Bender
Old 06-03-2008, 05:28 PM
danielhv's Avatar
John Bender
Just picked one up today for $29.99 after mentioning the catalog... Thanks!
-Daniel
Old 06-04-2008, 09:01 AM
cguarino cguarino is offline
Default How about this one?
I have the 94572 set with a big gun and small gun. http://www.harborfreightusa.com/usa/...bCategoryName=
The big gun seems to work way better than the small one. I'm pretty sure it is all about the nozzle size. Has anyone used these? Any hints or tips out there? Thanks.
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
Old 06-04-2008, 09:10 AM
frankh's Avatar
frankh frankh is offline
Default Little gun works great too
Go to www.hotrodders.com and do a search on HVLP spray gun set up or something.
There you will find detailed instructions on setting the gun with the cigar shaped spry pattern..You do this before you spray each batch,...takes only a few seconds and it makes a big difference.
Set 45 psi at the gun with the trigger pulled...i.e set the pressure while the gun is flowing air.
Thin the paint down a little more than it says in the instructions...and make a few practice passes.
These guns work great!
Frank
