06-02-2008, 02:01 PM
Vans Capacitance Fuel Senders - Which Gauge?
For some odd reason back in the day, I ordered my wing kit with the optional capacitance fuel senders. So far the only fuel gauge I can find that is capacitance savy, is electronics international's FL-2. This however, does not work with Vans style of senders. I've tried it.
So, those who have gone this route... who's gauge are you using with vans senders and getting it to work?
Thanks!
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
06-02-2008, 02:06 PM
You want the Electonics International FL-2C guage. I have it in my 6A and it works great with the Vans senders.
Regards
Jeff Orear
RV6A N782P
Peshtigo, WI
06-02-2008, 02:08 PM
If you are using a Dynon or GRT EFIS you can buy the converters from Dynon for $50 each.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
06-02-2008, 02:09 PM
Joe,
I've installed the Dynon converters and a Dynon D10 EMS, which includes the fuel gauges.
All works as advertised.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
06-02-2008, 02:40 PM
Dynon converters will work for the GRT ??? That's good. If true, that's about half of what the GRT converters cost.
Roger, Tucson, AZ
06-02-2008, 04:11 PM
Roger, Tucson, AZ
Should clarify that while I bought them for mine I have not turned anything ON yet. However, the converters output 0-5 vdc which is what the EIS is looking for, so no reason they should not work fine.
Wade Lively
-8, Flying!
N100WL
06-02-2008, 05:44 PM
We are at the stage of installing the probes in our RV-10 tanks. We have the float type on hand, but are planning to order the Skysport/ Westach capacitive probes as we feel they are more accurate. In my Rotorway helicopter I had these probes with a Vision Micro EMS and every time I would key the mike the fuel level would fluctuate. Has anyone had this experience, is this commonplace with capacitive type probes?
06-02-2008, 07:58 PM
Anyone want an rv-4 real cheap?
Regards
I wired in the the FL-2C yesterday, in any attemps to calibrate it at any fuel level, it wouldn't do a "sensor count". If I grounded the wire from the gauge to the tank to ground it would start counting... a continuity check of the same wire came back negative, like it should. Also, the manual gives a description of error codes, 1 through 5. I got error #6.
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
06-03-2008, 07:13 AM
Sounds like you need to call EI. If I am not mistaken, they have upgraded the FL2C (not sure if they call it that) so that calibration is now unecessary. I have an older model which needed calibration.
Give them a call.
Jeff Orear
RV6A N782P
Peshtigo, WI
06-03-2008, 11:31 AM
The FL-2CA will indeed work with the Van's capacitive senders. You need an "IM-CV" interface to connect to the Van's BNC connectors also.
For all you calibration needs call 877-318-6060 Ext 111. Mr. Dave Campbell is the calibration guru here at EI!
