Originally Posted by Chappyd
(snip) Can I run 3 things off each line and still maintain a high degree of accuracy?
Accuracy, yes. Redundancy, no.
This is typical RV practice, but be aware that a pitot problem (ice, bug, whatever) takes out
all of your airspeed/AOA instruments. Same with a static problem.
At least one Cirrus accident in IMC is suspected to be due to water in the static system
I think I'm the only one, but I used a separate pitot/static source for my AOA sport.
Bernie Kerr tapped the back of his cylinder cooling plenum for an ice-resistant backup pitot source on his first RV. He found it accurate to within a couple of percent through the entire IAS and power range of his aircraft (which surprised me)
