specifically the question has come up because I want to use a steel AN "T" fitting in the brake fluid reservoir. This is a pipe thread joint (so I don't think those same torque values apply), but the other two sides of the "T" will connect to the aluminum AN fittings on my fuel and brake lines.
Which leads me to another question - the fittings on the Bonaco braided stainless steel brake lines, am i correct in assuming these are aluminum? They're not blue, so maybe they are steel as well... of course if they are steel then I still have the mixed alum-steel joints where they connect to the AN fittings that go into the master cylinders.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
