re-tap brake reservoir?
I've got the Bonaco brake lines, and this uses an 826-3D "T" fitting in place of the nylon T fitting, into the brake fluid reservoir. When I screwed the fitting it, it was extremely tight (I have another post about this). When I removed it to inspect/add fuel lube, I discovered the first few threads on both the fitting and the reservoir are totally stripped. I'll get a new fitting, but the reservoir is $39, so I'm wondering if I can re-tap this to restore the threads? If so, what size of tap do I need?
Another question - when I replace the AN826 fitting, is it OK to use a steel one here instead of aluminum?
Thanks!
Phil
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
