Steve,
You wild and crazy guy
Sorry I could not resist. I just did this on my left wing and mine do not touch in the neutral position. They also don't touch when I run the aileron through the upper ends of the travel limits (32 up to 17 down). I think some have had issues with this, but it might be the rivets in the push rods. Is the rod touching or is it just one of the rivets? I had the rod ends welded on my mine. I will say that the push rod gets real close to the rear spar but it does not touch.
Hopefully someone else will chime in and show us some pictures of theirs.
Cheers
