Old 05-28-2008, 10:09 AM
kcameron kcameron is offline
Default Who sells 1/4-20 aircraft bolts?
When reassembling the alternate air box to the front of my fuel injector servo, I saw that the threads on one of the 1/4-20 bolts are bugered up. I thought it would be no problem ordering replacements from ACS but they only carry 1/4-28.
The bolts are 1/4-20 with drilled heads and 2" grip. I guess I could find some at Home Depot and drill them. They'd probably be fine since it's not a demanding application. Still, I'd rather use aircraft bolts if I can find them.
Is there even such a thing as a 1/4-20 aircraft bolt?
Kevin Cameron - Fresno, CA - E79
N493DB RV4 Flying
IO-360-A1B, 10:1, Straight-Bore cylinders, Gapless Piston Rings, Hartzell CS Prop,
AFS3400-EE, TruTrac DFII VS, Aera 660, GTX 335, GDL 52R,
XM Radio, SL30, SL40, PMA9000EX, MicroTrac 300 APRS
Old 05-28-2008, 10:25 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Try GAHCO.
Advertiser here.
http://www.gen-aircraft-hardware.com/default.asp
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-28-2008, 05:47 PM
TankerBob TankerBob is offline
try McMaster Carr, I don't know if they have them. But they have lots of stuff and an easy to use website.
www.mcmaster.com
Bob Sheets - PA ANG - Pittsburgh IAP
KC-135R/T - For Pay
RV-8, N571RV - For Fun
Old 05-29-2008, 12:16 PM
Thanks Guys.
I hadn't thought of McMaster Carr even though they're one of my favorite vendors. You're right about the user interface. It makes it easy to narrow down to the exact part you want. They do carry drilled-head (non-aircraft) bolts but they don't have a 2" long 1/4-20.
The GAHCO website is much more difficult to navigate. I couldn't find it on the website so I called them. They suggested the MS20074-04-24 but don't stock it.
I'm looking for the MS20074 bolt on the web but no luck so far. I'll probably end up at Home Depot.
N493DB RV4 Flying
Old 05-29-2008, 04:06 PM
gtmule gtmule is offline
Originally Posted by kcameron View Post
Thanks Guys.
try www.coastfab.com (call them, they'll find it!)
