Old 05-27-2008, 12:25 PM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Default Fuel Flow gage
Hi All
When I install my new fuel flow transducer do I have to install it between the carburetor and the fuel pump or can I install it after the fuel selector valve inside the cockpit?
E.I. FP-5L with FT-60 transducer
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
Old 05-27-2008, 12:39 PM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
Hello Dayton.
I did qute a lot of research on this subject. My engine if fuel injected and it was recommended to place it down stream of the engine driven pump and before the fuel injection servo.
I hope this information helps. I am using the Floscan Transducer with the Dynon system.
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
Old 05-27-2008, 01:05 PM
N941WR's Avatar
N941WR N941WR is offline
Dayton,
You just started one of those never ending debates.
The ideal location is just before the carb/fuel servo with six inches of straigh pipe before and after the FFG.
That said...
People have put them between the fuel valve and electric pump, between the electric pump and machancical pump, and...
You get the idea. All the locations seem to work just fine. I put mine between the gascolator and machanical pump so there is at least some type of filter prior to the fuel hitting the FFG.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-27-2008, 01:08 PM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
Dayton,
I have the following setup: Lycoming O320 (160HP), with E.I. FP-5L with FT-60 transducer. But I can only offer one data point. I installed mine after the engine mechanical fuel pump & before the carburetor. In that location it has been very accurate.
Wish we had data for other locations as I thought about cockpit location also.
Bill
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 05-27-2008, 01:41 PM
Rivethead Rivethead is offline
Here's the location I used. It's unknown how well it works, for me at least, since mines not flying yet. It's all good pick a place and stick it there.
http://www.vansairforce.com/communit...uel+transducer
It's a huge topic do a search (fuel transducer) and see.
Old 05-27-2008, 01:49 PM
Mel's Avatar
Mel Mel is offline
Mine has been working perfectly between the selector valve and the boost pump for over 15 years.
I have inspected aircraft with the transducer mounted in place you can only imagine. They all seem to work fine.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
