Old 05-26-2008, 04:10 PM
David_Nelson's Avatar
David_Nelson David_Nelson is offline
Default Firewall penetrations for IO-360-M1B w/ AFP
Hey Gang,
Do the fuel injection firewall penetration locations as documented in the plans work well for a Mattituck IO-360-M1B w/ AFP fuel injection? This is for a 7A.
And since I'm here, any recommendations on the location of the fuel purge bulkhead fitting? I was thinking of placing it next to the fuel bulkhead fitting. Both would be 45 deg fittings.
/\/elson
/\/elson
RV-7A Tip-Up
NW Austin, TX
