1st let me say that in spite of it being a common squawk that lots of folks have had to learn to live with hesitation, stumble, bogging ect
is not normal. The reason a lot of people live with it is that it can be very tough(read expensive) to isolate and fix. The previously posted link to Sac.sky-ranch covers the possabilties quite well. In my experiance the no.1 most likely cause is a fuel issue. This is were I would start. Make sure you have proper pressure and flow to the carb, make sure the
part number (not model number)carb installed is correct for the engine, make sure the finger screen in fuel inlet is clean and in good condition, check for any leakage as indicated by stains, check idle mixture setting, at 800ish RPM a
slow (3 sec.)pull to idle cut-off should produce a 50-75 RPM increase folowed by shut-down, and finally check for correct carb float and float setting. If all checks out ok and you still have a problem check and see if the one piece venturi AD has been performed on that carb. If so borrow a carb that it has not(still two piece venturi or manufactured new), install and test. If this fixes your problem either have your carb rebuilt with a new tempest venturi and main jet installed, or buy a new tempest carb. I have found this squawk is commonly caused by a low quality one piece venturi and/or mismatched venturi/main jet in rebuilt carbs. Some engines will require a richer main jet when using the one piece venturi. Lots of good info relating to carbs @
www.msacarbs.com Good luck, Russ
