Old 05-25-2008, 06:50 PM
prkaye prkaye is offline
Default torque rudder pedals
Each brake pedal is attached to the rudder pedal assembly (the poweder-coated steel assembly) by AN3-5 bolts, castle nuts and cotter pins. Should these be torqued? If they are torqued, won't the friction prevent the brake pedal from rotating smoothly/freely in the assembly when the brakes are applied?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 05-25-2008, 06:59 PM
terrykohler terrykohler is offline
Do not torque. The shank of the fastener serves as a pivot for the pedal. The nut and cotter are just there to keep the pin in place. In hindsight, I would have preferred to use one long bolt passing thru both ends of the pedal. This would help to prevent any twisting moment.
Terry
Old 05-25-2008, 07:01 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
edit .... already answered
